Boiler Service
14 Jan 2005
Glamorgan
My Worcester Bosch Greenstar 35 Combi boiler has just been serviced under an annual Homecare agreement. The engineer has provided me a form with only 'tick boxes' to say that it has passed. He has however, written in the margins the following measurements:
35.29
9.4
0.0006
62 ppm
What do they represent and what are the tolerances for this type of boiler?
He has also made a suggestion of fitting a "Magnabooster 22mm Combi" to prevent system clogging. It apparently comprises of a magnet which attracts particulates within the system. The boiler is only 4yrs old and the radiators were flushed during installation. Is it worth the cost at £230 a pop?
Cheers
35.29
9.4
0.0006
62 ppm
35.29 = kw input rating.
9.4 = CO2%
0.0006 = ratio CO/CO2
4.3% O2
30% Xs air.
62ppm = .0062% carbon monoxide in air.........1% would be immediate death within 1-3 minutes. :mrgreen:
Those combustion readings are spot on.
Cheers
System corrosion can be more of a problem for modern boilers, as it can lodge in the heat exchanger. It can cause a loss of efficiency and eventual breakdown. Some systems suffer more than others.
Obviously it is better that any corrosion is caught in a filter before it enters a boiler. Making sure that you check the concentration of corrosion inhibitor in your system helps keep corrosion to a minimum.
I would be going for the Fernox TF1 if it was me.
Better than fitting a filter to catch crap, is cleanning the system to remove it and then treat with inhibitor.
35.29
9.4
0.0006
62 ppm
9.4 = CO2%
4.3% O2
30% Xs air.
Unless you read the O2 and excess air off the analiser printout how can you possibly know the figures. :rolleyes:
Put Heatgas out of his misery Misterdubya :mrgreen: , can't see what the CC has to do with it. :confused:
NO chance! Ive had too many posts deleted and I aint risking another one. I like the advice in the CC and I'm not risking it on some newbie. You should know that. ;)
9.4 = CO2%
4.3% O2
30% Xs air.
Unless you read the O2 and excess air off the analiser printout how can you possibly know the figures. :rolleyes:[/quote]
:rolleyes:
How is this anything to do with gas safety? , give the guy an answer. :rolleyes:
[quote="gasafengineer";p="20927]
Those combustion readings are spot on.[/quote]
Are you sure thats correct?
(In fact I think it is but it just looks wrong!)
