- Joined
- 10 Oct 2011
- Messages
- 16,396
- Reaction score
- 4,042
- Country
Take a break Dan FFS...No it wasn't .
Absolutely naff all point installing a high powered combi. Look at the other thread that's popped up this evening with his 32kW Wooshitter.
I always recommend a 28 kW or 32 kW because they can provide more flow in the winter.
Something I lack Dan..Can only speak from experience Steel .
Something I have never seen ( in the public domain ) are efficiency ratings for boilers that are modulating. Maybe a boiler is 90% efficient at its full output of say 24 kW but how efficient is it when modulated down to say 6 kW ? Can these figures be made avialable to people who are choosing a new boiler ?Boilers with a large modulation range have a lower minimum power output, and so are more efficient when running your heating.
It will all depend on how the boiler is controlled.Maybe a boiler is 90% efficient at its full output of say 24 kW but how efficient is it when modulated down to say 6 kW ?
When a boiler is quoted as having an efficiency of 90% that is for a flow temp of 80C and return of 60C, i.e above the point where condensing begins.
Bernardgreen must have something useful to say, he certainly has a better thank you score than your good self
I wasn't talking about the theoretical efficiency, as calculated using the SAP equations, but the measured efficiency as given in manufacturers' specifications.In which case the efficiency when the return is below the dew point (where condensing begins) will be ( or should be ) several percent points higher than 90%. I do not think that is the case, I believe the quoted 90% is when the boiler is condensing and that the efficiency drops ( far ) below 90%. This seems to be borne out by the figures below where summer seasonal efficiency drops to 79.4% compared to ( quoted ) 90.1% winter seasonal efficiency.
