Hi, I've recently had a Worcester 30i Combi fitted to replace a system boiler. And after a week or so, it tripped the RCD.
I managed to isolate the problem to the circuit the boiler is on, all other circuits would run fine, but the boiler circuit would trip every time, until I disconnected the wiring that was connected from the plug socket to the boilers Fuse switch.
I managed to get the engineers who fitted the boiler back around, but magically when the boiler wiring was connected again it started running, he messed around with the rest of the wiring on the fuse which caused it trip again, but he blamed the wiring on the rest of the loop in the circuit.
Since then it has tripped again, and same thing, RCD did not reset until I disconnected the boiler wiring from the socket, every other plug worked fine on, and when I connected the boiler back out was up and running again.
As far as the fitters are concerned it was running so there's no issue on the boilers side, but that's the only thing that's been added since I moved in over a year ago, and it's only tripped since that's been added.
The boiler has been fitted directly above the sockets and the fuse is running out from that socket.
