Boiler Upgrade Advice
28 Mar 2010
Argyll
I have a rather old floor standing Gloworm Hideaway (60,000Btu/18Kw) output boiler. Its fitted in a utility room, under a 600mm kitchen unit. I suspect its somewhere in the region of at least 17 years old !
Although it runs perfectly, this winter 2 rooms were never quite warm enough, and after checking the calculations for the room size I changed the 2 radiators to double radiators. Both rooms are much warmer now.
Downside is, I think the boiler is now struggling with the extra, and to be honest, being quite a large 4 bedroom detached house, I think the boiler's always been on the light side.
Anyway, this summer I'd like to change upgrade the boiler. Here's the rough spec:
4 bedroom house with hot water storage tank etc.
12 various sized radiators.
Circuit is pretty standard with 2 way programmer, (heating & DHW)
Existing flue is a standard square balanced flue, that will need to be changed
I'd like to upgrade to a high efficiency condensing boiler that will fit into the same space with minimum of hassle. I don't want to convert to a combi boiler. Basically I only want to change the boiler & flue.
So question is, could anyone suggest a reasonable quality free standing boiler, that will fit under a standard kitchen unit?
Intuitively, and without doing the calcs, I'd have thought a 25-30Kw high efficiency condensing boiler would be about right?
Advice on boiler anyone?
Potterton fsb (floor standing boiler) fits into a 600mm under counter space
Can't comment on kw's required too many unknowns. I suggest you use the sedbuk calculator
Thanks - 26.5 Kw from the SEDBUK calculator.
These are my choices so far:
Worcester Greenstar FS 30CDi Regular (30Kw) £1200
Potterton Promax FSB 30 HE (30Kw) £760
Ideal Mexico HE 24 (30Kw) £1200
The Potterton seems a good bet?
I would keep the boiler you have it will probably out live a new he boiler maybee you could zone the house & fit a higher output circulator also look to up grade system pipework & rads to convectors if they are not already.
