Just taken my monthly gas reading and shocked to see I have used almost 5500 kWh of gas since this time in November. 190 kWh per day. The month before I was using around 50kwh per day. I appreciate the weather has been cooler but 5500kwh in a single month is insane for a small, reasonably well insulated house. By my maths my boiler would have to burn flat out, non stop for something like 13 hours every single day to use that much, and clearly that is not the case. The heating turns on at about 8am and off at 10pm, stat set to 21 and boiler fires intermittently throughout the day, never more than a few minutes at a time after initial heat up.
I know my readings are accurate, I know I don’t have a leak so cannot fathom how I can possibly have used so much gas in a month. The only thing I can think of is a recent boiler service- could an error cause my boiler to be burning excessive gas? It’s an ancient glow worm ultimate, cast iron, non condensing, non modulating. Is it possible it could be out of adjustment and burning more than in should? I’m not sure if that’s even possible but if it is the heat would presumably simply be wasted out of the flue? Should I be asking the engineer who serviced it to return? The other thought is a faulty gas meter, but I understand this is very rare?
