am i missing something or is the current vent of 50% of required free area not 50% of what the manufacturer recommended? if so the boiler has always been "unsafe" but its only recently that the regs were changed to raise the classification to a potentially more serious one. quite rightly IMO. the HSE will probably have raised it due to a death or serious injury. can anyone think why the HSE would have a direct reason to get rid of old boilers? nonsense i think.
off the top of my head the definition of At Risk is a situation that could cause danger to life or property. it's the engineers opinion based on a particular regulation. if you don't agree with that engineers opinion then get another.
IIRC the 90% of free area figure is acceptable because it takes into account the possibility of measuring errors.
The current regulation ( 1st June 2008 ) requires 90% of the ventilation stipulated by the manufacturer.It was previously 50%.
incorrect. if you currently have 50% and nothing has changed since installation then it has always been wrong. only after the HSE changed the classification has the real push by conscientious engineers to get the vent upgraded.
If an engineer decides that an installation is AR, in this case if ventilation is less than 90% of the boiler manufacturer's recommendation, he should ask permission to turn the boiler off. At risk surely refers to the possibility of a problem at some unstated future time such that corrective action must be taken before the boiler is turned on again. It can hardly be a matter of opinion because a precise measurement is given. A registered engineer should have no problem checking this. Otherwise how many opinions do we need ? AR is not a matter of opinion; it is a failure of an installation to meet a required standard,
again incorrect. i do not need to ask to turn off an AT Risk boiler. i turn it off and its the customers decision to turn it back on if they choose. the corrective action required
should be noted on the paperwork given to the customer and also verbally advised.
in stating it was a matter of opinion i meant in the general context of an AR situation. in your case the ventilation is well below standard and is clearly AR. AR situations in general can often be grey areas and can quite often be a matter of opinion. ask ten men their opinion and like it or not you will get an argument about it as is often seen on this site. a regulation may be clear, its bearing on an actual installation may not. i'll admit its a difficult one to explain to a non RGI.
the 10% rule works in your favour by giving you the benefit of the doubt. if i were you i would complain about the level of service. there really is no excuse for not knowing how to measure a vent and it's subsequent classification. i doubt you will get far. upgrade your vent to the correct standard using another firm and bin the current firm.
You appear not to be aware of the regulations. The following is taken from information I received from HSE Infoline Admin two days ago.
May 2005. " Any existing gas installations with below 40 per cent ( 0%to 39%) ventilation
should be deemed At Risk and the appliance should be turned off with the gas users permission........"
1st June 2008. " all installations providing less than 90% ventilation will be regarded as putting consumers AT Risk"
It follows that you are wrong to say that my boiler has always been unsafe.If you still think you are right, I suggest you contact HSE rather than shoot the messenger
lets put it another way you may understand.
1) your boiler is installed in the early 1900's.
2) the correct ventilation is probably not installed with it. we believe it is only 50% of the required amount. it is NTCS- INCORRECTLY INSTALLED.
3) due to a reason presently only known to the HSE the requirements change in early 2005.
4) the HSE generously give owners a period of grace so they can get their heads round this new classification and allow anyone with 40-89% of the required free area very generous 3 year period to get ther "s**t" together.
5) most don't
6) mid 2008 everything below 90% is AR
7) life as we know it ceases to exist.
8 ) a new dawn arises whereby people actually start to get the proper ventilation for their OF boilers.
9) you finally get the message and come on to a random site plucked from google to ask ridiculous questions, argue with knowledgeable regulars, misunderstand most of the advice given and generally act like a complete a**e.
your ventilation has been wrong since jesus last walked the earth. get it upgraded and do us all a favour.
