Hi Guys
Newbie question - sorry if it's a really obvious one but I've not had much to do with boilers or GCH before in my life.
We had a radiator fall off our wall recently. A plumber re-fixed it on and sealed the pipes and everything appears to be OK in that regard.
However, since then, the water flow in the shower has been worse than usual. I also noticed a small red box in the boiler room is hotter than normal now also.
Not sure if these things are all related, but I recall a friend once mentioning they nearly blew up their boiler because it had air in the system, so just wanted to check if there's anyway these things could be interlinked, or if there's someway I can 'release' to see if any air is in the system?
Again, sorry if the post is a bit scatty - if you need more info, let me know.
