boiler
slugbabydotcom
Heating is on. Answer: YES
You. turn hot water on. Answer: YES
Hot water demand is satisfied when you turn the tap and off. Answer: YES
Your diagnostics!
Instead of shutting off by the HW flow switch it shuts off by the thermistor as the flow switch is stuck on.
Boiler will not go back to CH until you turn the tap on and off sharply to free the sticky HW flow switch. Answer: YES
Yes you are quit right but in addition I also have my original post problem
What I have noticed is that the boiler first fires up, then shuts down, the fan keeps running but the burner will not relight under normal heating opperation.
Thank you,
:unsure:
What I have noticed is that the boiler first fires up, then shuts down, the fan keeps running but the burner will not relight under normal heating operation.
:unsure:
When the boiler fires up. How long does it run for before it shuts off again?
Do you have to reset for it to start again or does it start on its own 3 mins later?
Someone mentioned combi 80 earlier and confused me a little
We are talking about a C-M britony combi 80, yes?
Then you said
Rob if CM stands for chaffoteaux & maury then your right on the ball
Now I have re-read your post I see you have a brittony combi SE :!:
When a fault occurs on the SE a combination of the lights between 30 and 80 is shown to point you in the right direction.
What lights are shown when the fault occurs?
