Hi there,
Everything has been working fine, bar the odd buzzing noise, kettle noise or banging noise from the heating system up until now. Turned the CH off, using the winter/summer setting about 2 months ago, and now put it back to winter, and well nothing.
The thing doesn't do anything, whereas before you could hear it fire up, start whirling and the pipes expand with hot water (v noisy!) and the rads would get hot. Not anymore, nothing happens. I turned the unit off and on again, this time a really loud drilling noise, coming from the front of the boilermate, behind the panel. I've done a search on here and read it could be a board or control unit or somesuch. How hard is that to change? I've also noticed that the pipe marked heating system is hot at the top, but not after the pump but also the pump is not whiring (the other one is, marked back to heater unit or something, sorry am at work and going from memory).
The timer has been moved from manual on, to timer, to off, and nothing seems to make any difference. The unit is acting the same in any setting. The drilling sound had started about a week or two ago, but it was nowhere near as loud, and was for about 3 seconds or so. Now, its loud and lasts about 40 seconds or so.
Any help greatfully received. Thanks!
