Nick, you are making a lot of assumptions!
An ion exchange softener normally has only a very small amount of chloride in the softened water and thats no problem to anything. But sometimes they are abused or go out of adjustment or are not maintained and then the chloride level becomes higher. This is only a problem with the secondary heat exchanger on a combi boiler.
The sec HEs are now mostly stainless or copper and are relatively cheap and although the boiler makers will mostly say its not permitted thats to cover themselves and many chose to ignore that advice without much problem.
Few areas are so hard that filling the system with mains water will cause any problem if there is inhibitor and the boiler has been correctly commissioned.
Its a finely balanced argument if its better to fill a system with softened water or with unsoftened water. Generally most people would say use the mains water.
Tony
Tony
