Bonding gutter advice
25 Nov 2024
I have a 1930s semi-detached house with had Rosemary tiles on top of boards on the rafters. We're having it replaced with membrane + batterns and Redland 49s, and I'm looking at how to join the roofs. I wish we just got newer Rosemary tiles but the roofer insisted on these and we made the decision asap due to the storms. Oh well.
Anyways, now my roofer is saying that they tried but can't use a bonding gutter, they are small Rosemary tiles with a lip and so they're getting raised too much and they'd need to replace all of the middle tiles. They also can't nail them in to the bonding gutter and so they're slipping. They recommend ridge tiles instead (dry-fix due to them needing to be mechanically fixed now).
My parents had this done years ago but it seems like this is an older approach. Are using ridge tiles still considered ok?
OP,
Change roofers springs to mind but its not easy getting any kind of roofer in the British monsoon season.
You might also get a bad to worse roofer if you swapped roofers in mid-stream?
Was it ever discussed with the neighbour's that replacing their wet valley with a dry valley while the bonding gutter work was going on might have been a good idea?
Are both planes - front & rear - of the roof being done?
The thing is with bonding gutters is that the prep work must be spot on, and that hidden detailing can take a little time that some wont make - they just rush on , make it look OK from below, take the money, & never return.
When they claim the job is done then get up into your & your neighbour's lofts, & look for leaks from below.
Why not post pics showing a larger context of both roofs - & a pic showing how the valley & the BG are going to meet(?) & discharge at the elevation gutter?
Thanks for the advice and the clear photos! We can cut the battens on our side to lower it but I'm not sure how we could lower it on the neighbour's side since they still have boards on the rafters and nothing underneath. The roofers were implying that their tiles are rising because of the height of the gutter on their side when it's on their boards. Would lowering it on our side but keeping theirs where it is help to fix their tiles rising?
Also, the roofer said that we should use a dry ridge system over the boundary instead to avoid disturbing their tiles, and they've gone and installed it. Is this a bullshit idea and should I get them to remove it?
