bonding soil pipe
27 Nov 2006
South Tyneside
Hi, can anyone tell me the best method of bonding your soil pipe in teh bathroom? can you buy the earth straps to fit around the 110mm pipe?
Any Advice appreciated
i'm going to assume that since he wants to bond it then it will be cast iron..
have you TRIED drilling cast iron? yet alone tap it...
do soil pipes even need to be bonded??
I soppose it IS an exposed metal part...
just slap a dozen layers of paint on it and call it insulated...
You can get stainless banding, with holes punched in it, for this purpose. Not widely sold as most soil pipes are plastic now.
:!: because it is a metallic service entering the bathroom
It will be in contact with earth at the other end so will introduce an earth potential which is unlikley to be the same as the CPCs and the other metalwork.
I agree, although I was thinking that if it was only the soil pipe that was metal and all other pipes connecting to it were plastic then, if boxed in then it would no longer be an exposed extraneous conductive part!!
Lets apply some common sense here - is it exposed conductive metalwork in the bathroom?
Is the stack metal and outlet from WC non conducting?
Yes. Do you have some kind of problem with it?
yet alone tap it...
Why would you think that they don't?
You suppose correctly.
You need to get a refund on that training course fee. :rolleyes:
Shouldn't it also be main equipotentially bonded if it is in contact with the general mass of earth too? :rolleyes:
RF Lighting said:
Yes if in a bathroom
surely if they are in contact with the ground they need to be main bonded not just supp bonded.
i tend to think a pair of clamps is probablly the easiest soloution though.
