Thinking about the jointing techniques that used to be found on cast iron soil pipe (sockets caulked with hemp and tar, pointed with mortar etc) does the pipe even qualify as a 'conductor'?
Worse case, the bottom bit of pipe is at ground potential. The next bit up is at the earth potential as supplied by the incoming PME neutral......
The joing id non conductive so there is a potential difference across the joint. And the pipe is venting a methane and air mixture from the sewers..........
On a radio transmitter site the metal soil pipe ( installed before the building became a transmitter site ) had to have each section bonded to the next section just in case there was spark across a joint. The radio frequency induced voltages were much higher than one would expect to find between domestic earth and ground.
