yes as they are both from the same cws.
the flow to the bath is ok but that is well below the cws.
your showerhead isn't, and you need 1 l/min per side to kick that pump in.
so the higher you raise your showerhead the less l/min your going to get.
so you need the max flow your gonna get the least restriction the better.
you'll be amazed what a restricted iso valve can do.
you may be ok, but its alot easyer that moving a tank.
so check one of them then go from there.
