Bosch SG145E16GB
Door seal is OK, just changed bottom door seal. Ran a 30min cycle all ok. then ran 150min cycle and water was poring out of the front of the machine during the first 60 mins of the cycle. Then let it run for the remaining 90 mins,no problem. During this period opened the door to check the water level and it was at the normal level and water was not leaking out of the machine
Spray bars are intact and not cracked.
Could it be the water inlet valve?
