Bosch Dishwasher Won't Fill
19 Aug 2006
Essex
Disconnected and moved the dishwasher to tile the floor. Reconnected the dishwasher and ran rinse cycle to make sure that all was working ok. It filled and drained fine. Found slight leak on the water inlet pipe so disconnected dishwasher again to tighten joint (didn't need to move the dishwasher to do this). Reconnected dishwasher to plumbing and now it won't fill.
There's very good water pressure to the dishwasher's inlet pipe. There can't be any kinks or twists to the inlet pipe as the machine initially worked fine after reinstallation. If I fill the machine with a bucket of water, the machine goes through all its cycles ok and also drains ok. Any ideas?
