Miele G977 Dishwasher fault
See a couple of these machines where the air vent has worked loose & caused leaks. Look inside the machine on the right hand side, about 3-4" up from the base there is a round plastic air vent that connects to the water jacket on the outside of the machine. Try to give it a nip clockwise to make sure it is tight (but don't over-tighten it). You may have to use a pair of long nosed pliers or similar to get some leverage to turn it. Then run the machine on the hottest program & recheck for leaks. It may be an advantage to remove the right hand panel just to observe there is no leakage from the water jacket itself.
Thanks Zipper,
Ill try that vent to ensure its tight - tomorrow now tho. It has been run 3 times so far on the hottest setting and no water leakage yet. Ill run it again in a minute and have a look in the morning for water.
I'm guessing you think it must be a leak from somewhere and will more than likely happen again?
I too have got the issue with the Inlet/Drain error. I have checked all filters which are clear. We had a flood from the adjacent sink a few days ago with water going under the dishwasher. I am guessing that this has caused the problem. Do you think that this is likely? In which case do you think it is fairly easy to rectify? Is it just a case of tipping out the water that has got in at the bottom?
Hi cjfb,
I would imagine that no water has leaked from the dishwasher but the water has collected on the plate from the sink leak. if you pull your dishwasher out and put a towel behind it, when you tip it back you will have water run off the metal plate at the bottom. I would recommend removing the bottom plate and drying everything off as its really simple to do. I would also suggest runing it once or twice whilst its out to make sure everythings ok before putting it back into place.
Just follow the instructions already on here to remove the bottom plate - it is simple - Zipper was a great help also.
Hope this works for you.
Kind regards
Ross
Ross,
Many thanks for that. I have done exactly that and the machine is now working. I have learnt something new about how Miele set things up which is brilliant.
Charles
Hey Charles,
No problem. I love miele. I had to replace the door seal on my now 9 year old washing machine a few weeks ago. they're great they just work and they keep everything simple. I have only ever brought Miele but after watching everyone else I know keep replacing they're white goods and I'm still on original products they are worth every extra penny.
Glad it's all worked out mate.
have a good year - take care
Ross
The inlet/drain light flashing indicates a fault (obviously). But don't automatically assume it is an inlet or drain issue. There can be several seemingly unrelated causes for this error signal. There may be a leak & water on the base-plate has activated the flood protection system (lean the machine forward & see if water runs out). There could also be a problem with the circulation motor (jammed impellor), a defective pressure switch, non-return valve jammed....as well as the obvious "inlet & drain" timeout issues.
Hi Zipper
Is it possible for me to get the fault code guide that supports the indicators on the programme selector - I am having similar problems on the G977?
