- Joined
- 11 Jan 2004
- Messages
- 43,885
- Reaction score
- 2,873
- Country
Hi guys
I have the above dishwasher that started leaking.
I looked underneath to see if I could see anything obvious, but the base is sealed.
I checked the waste pipe and there was some gunk in there so I cleaned it out. Since then I have run it 5 times without incident then it leaked again.
I didn't notice on the previous clean-ups, but when I cleaned up this time, the water smelt bad, suggesting it was pump-out.
I am led to believe that this machine has a leak prevention system with a float switch that puts the machine into a pump-out mode if there is a water leak, but this hasn't happened.
I have checked to see if it is a straight-forward door seal leak but this does not seem to be the case.
I have had a quick look at other Bosch dishwasher leak threads, but can't find anything appropriate.
Has anyone got any pointers to help me?
Cheers.
Cheers.
