We're getting fed up with a series of boiler problems which so far British Gas have been unable to solve.
Jan 01: heating/hot water had failed. BG engineer reset overheat cutout switch and repressurised the boiler (it had gone low).
Jan 02: boiler overheat cutout switch had tripped several times. BG eng reduced system pressure & repressurised the expansion vessel.
Jan 22: boiler worked fine for several days then started banging when hot water run. BG eng replaced the pump & cleaned the bypass/thermostat tube.
Jan 29: boiler worked ok for a couple of days & then started banging again. BG eng replaced the main heat exchanger & put in 2 lots of fastcleanse as we also booked a power flush for Feb 17.
Feb 03: Boiler stopped producing heat/hot water but NO overheat cutout switches tripped. BG eng replaced the fan & air pressure switch. This worked for about 3-4 hours but failed again, possibly after using the hot water.
BG think there is muck in the system which may be causing the initial problems of overheating and tripping the cutout switch. However tey're currently at a loss as to what has caused 2 fans to fail. Can anyone help/advise?
