Hello
I have just had a showerbath and back to wall toilet with concealed cistern installed and would like some advice on how to box the cistern in. The problem is the toilet is very close to the path so I would like to find a way to make one side of the box curve with the bath, as I feel doing a normal straight side wouldnt look right. Can anyone describe how you would build this box? including how to make the frame and measure up and cut the waste pipe hole etc. Bear in mind I am a novice at all this so the simpler the better!
Thanks in advance
Thanks in advance
