Now here's a question. I need to swivel the 90 degree waste pipe round a bit, which means removing that AAV (I could re-attach to the other side), but do I need it? Since that bathroom was put in we've had a ensuite put in the loft room above and as part of that they re-directed the soil pipe and removed the external vent...
One thing to consider regarding bends - can you use the 'melt the pipe' method? You may be able to get some smoother sweeping bends. Will only cost you one pipe to try it out. Also if you are boxing that pipe in then you may be able to make it a bit more direct rather than following the path you have done.
