In which case the earth connections seem to be fine, so as our goodly JohnD suggests, its a wire continuity issue.
The light clusters are fed from wiring on one side only (not sure which) and then the wires continue to the other cluster, so the fault is between the first light cluster and the supply.
Good luck - if you see any suspect wires, remember the plastic insulation could be intact but the conductor within could be snapped, just to add to your working pleasure......I have a test lamp with a probe sharpened to a needle....pierces the insulation but allows it to reseal again after.
John
John
