I have bought fully refurbed air compressor last month but it failed twice. I am no electrician and I would appreciate your input!
It is Sealey SA22503, 3hp with 50 liter tank, 230V 1ph, 9.3A input with the plug go into the domestic wall socket. The socket is about 5m from the main fuse board and I used 5m extension cable (with no reel) which is unwound. After I started to use it for the first time for sand blasting about 30 min., it slowed down while it was pumping and it stopped. The fuse on the compressor cable socket as well as fuse on the extension cable were blown, the main circuit breaker on our flat has tripped, too. Strangely, overload button on the compressor didn't popped out....
I have sent it back to the manufacturer for warranty repair, they fitted new stator and rotor, it came back. BUT after 45min start using it, it failed again! This time the over load button popped out, the fuse are blown again but breaker of flat didn't tripped. I am a bit surprised as I have used similar compressor but 2 hp from Machinemart before with similar set up but it never failed.
The chap from the shop is very nice and offered me another warranty repair by manufacturer but he pointed out that it is rare that it failed twice. I just wanted to make sure if my flat power supply is good enough - I don't think I can ask for repair next time.
How can I check the current on the socket - I have circuit tester up to 10A. Should I use a socket attached to the cookers switch? To use the kit in our garden, I must use an extension cable (unwound) - do you have any recommendation? Any tip or comment would be very much appreciated.
