Are the connections OK? A cable fault could be something cutting into it, such as a sharp edge on a backbox, a nail or screw into the cable, rodent damage, etc, or even a badly manufactured length of cable - Atlas Kablo comes to mind.
Fuse in the FCU ? I am not talking about the plug, but the wall socket the plug connects to.There isn't a shower. We had the wiring installed but in the end realised that our combi was better than any electric shower would be.
Its happened twice so far, both times in the morning about twenty minutes after being turned on. After replacing the fuse it worked fine for an evening.
Initially I wondered if there was a water leak because it tripped about five minutes after our morning showers but couldn't see any leaks, the evening after I replaced the fuse we had a couple of showers and didn't trip it.
My first thought was that the element in the heater had failed but the water is still coming out warm or that there was a dodgy solder joint that was failing when the unit heated up but it sounds like the fuse in the plug not failing rules that out?
What's the make/model of the bidet ?
Or worse, if the OP is a little unsteady on his feet on his return from the pub...Also, since this is a bidet, there is a chance of water ingress. Where is the location of the plug? It's worth checking the wall socket for water ingress. This could be due to water unwittingly sprayed at the socket....
