Hi all, installed some isolation valves and installed some new copper 15mm pipe I was going to go full push to fit but the tap connector didn't fit the push to fit so I had to go for compression. The issue is in the past the olives have been copper and it felt easier to make a seal. Currently I have 5 leaks, small drips but it's still not acceptable. I'm scared to overtighten them as I expect if I keep tightening the olive will split like with copper olives and I'll be left in a worse place.
Should I undo all the pipes replace the olives with copper and try again, should I try and tighten them past what I think is the maximum it should be tightened? Or should I undo the joints keep the brass olives that I've already tightened and add some plumbers tape to each pipe?
What would be the safest?
Thank you in advance
