I have a number of these lights to fit ... 9
http://www.tlc-direct.co.uk/Products/GLBRICK.html
The bricks have been left out at appropriate places in the wall runs.
The cable has been run into place and looped in and out of the holes ... 3 lights per run ... 3 runs of it, so for each run the cable runs to first light, loops onto the 2nd etc.
I used HiTuf: http://www.tlc-direct.co.uk/Products/HT1dot5slash3.html
Issue is the physical entry of cable into the aluminium back box ... the box has 14mm holes fitted with rubber grommets, but these are way to small to take HiTuf ..
All the glands I have looked at that would take the cable would require a huge hole to be drilled in either side of box and in any event the glands are physically too big .. and would not allow box to fit in the brick space.
An option could be to remove the hard outer sheath and try to only take the inner more flexible cable 7.5mm o.d. into the box.
Fit a simple grommet ... but can't find one for sale anywhere that would fit the existing 14mm hole, and once fitted will be a good fit for a 7.5mm diam cable.
The hard outer sheath would only be removed within the wall 'cavity' so does not really impact protcetion.
