So after a hiatus of nearly nine months - I went back at this. Pushing the my other mower without a self-drive provided the necessary motivation.
I put everything back together squeeky clean but the engine is not catching. When I prime the engine and pull the cord, everything feels fine, moves nice and freely - little resistance but not loose, but the engine does not start. If I over prime it a little it will start to catch, so I over primed it alot and it ran fine for a few seconds, but then cut out. They suggests to me that carburetor is not drawing petrol out of the tank correctly - how can I confirm this?
The diaphragm and gasket are brand new. I took off the carburetor and re-positioned the diaphragm and gasket three times without success, the behavour is much the same afterward. The diaphragm wet and floppy now and curling edges, needs replacing perhaps?
Before I run out and buy another diaphragm and gasket, which will probably do nothing. What are the obvious things I should be trying?
Thanks all.
Thanks all.
