I know this in an old post, but i think I may have the answer for this. We tried everything suggested here and was about to pull my hair out, but then noticed that one of the connections in the battery draw had gone a bit green with mild corrosion.
I cleaned this off and all of the other metal connections in the battery draws, and gently bent out all the connections to make sure they were making a good connection with the fresh batteries. I also swapped the drawers over so that the one which had the worse corrosion was now contoling the LCD rather than the transmitter.
Then tried the re-learning procedure again.
All was working at it should once again.
Hope this helps someone
