I recently exposed some cooker wiring in my kitchen during re-plastering. I pinned the capping back to the wall but before I re-plastered, I checked continuity of all three conductors between the cooker switch and the connection plate and also for shorts, with a cheap multi-meter, to make sure I hadn't damaged the cable. Between conductors was open circuit and each conductor showed short circuit (between switch and outlet) so I plastered up.
Upon having the cooker fitted, the installer measured the circuit and informed be of a fault with the earth conductor. I didn't pay attention to any readings but was a little puzzled because I had checked for continuity and short circuit. In any case I pulled the cable out of the wall there and then and fitted a new one (under his supervision at no extra cost from a well known electrical retailer) and made good later.
I'm still puzzled as to why the earth conductor measured short circuit (between switch and outlet) when clearly there was a fault. What could I have done with my cheap multi-meter that would have exposed the fault?
