I've seen some manufacturers quote current ratings for rewirable versions those connectors that vary by approval body with 15A quoted for some approval bodies and 10A for others. This suggests that some approval bodies (IIRC UL and CSA) are ok with connectors being rated beyond what the standard rating for that style is and others (the rest of the ones listed) aren't.
12.16 Line and Neutral plug pins shall be fitted with insulated sleeves. The dimensions of the pins and sleeve shall fall within those given in figure 4a). Sleeves shall not be fitted to any earthing pin plug.
I can supply a copy of BS1363 if anyone needs it (read only).
Or you can get your own from the British Standards Online library access at your libraries.
