Hi to set the hotspur wallflame boiler correctly the flame should be blue with white/yellow flickering tips -- around a quarter of the flame white/yellow the base blue
I too have a Hotspur oil fired boiler. It was already installed in the garage of the house when I moved in 35 years ago.
I have always carried out servicing myself. Like martinph, I have fiddled with/ cleaned the OCV. I only know what I have found out by working on my own boiler. The only thing I have had to replace in all these years is the Honeywell Flame Sensing unit.(until now)
My problem is with the Ignition Transformer 200VA
Pri Volts 200/250
Pri Amps 0.9
50HZ
Sec ocv 8500
Sec Amps 0.021
Rating 70%
inner of Sec grounded to case.
It was manufactured by PARMEKO Ltd, England. for
BSA Harford Heating Ltd
Problem - any suggestions as to replacement transformer.
I am a pensioner now and trust it to break down during this cold spell.
Thank God I have a coal fire in the living room.
Any help appreciated - Slohaw
Thank you very much Boilerman2, I am a happy man.
After your post I removed the filter and the boiler ran ok. After my holiday I fitted a new filter and cleaned the gauze filter in the constant level unit and it has now been running successfully for a week.
(When the boiler stopped initially I removed both filters and washed them in clean CH Oil but in hindsight washing the paper filter does not work.)
I now have two Honeywell C551A flame failure units which I think work and a Honeywell Protectorelay R867A which my local plumber had in his shed, which does work!
( Now not sure whether to fit a new boiler before next winter after your Allegro example !! )
