- Joined
- 5 Jul 2010
- Messages
- 171
- Reaction score
- 1
- Country
Thanks Richard,
With regards to the Vermiculite, how exactly is this done?
The lintel area of the false chimney is going to be open allowing the flue to pass behind the lintel. My understanding of the Vermiculite is that you would mix it and add into the void which I don't have.
I don't know if you can get some kind of plate to go behind the chimney which the flue could pass through but that would hold the Vermiculite.
Any idea's?
The Victus plaster/screed instructions say to PVA before the screed (onto the bricks) and then onto of the screed before the plaster on top.
Have you found a problem with PVA'ing onto the brick surface?
Is the choice of using a sand/cement/lime render (5:1:1) as the base coat over the Victus screed merely one of cost? or is it a better way of doing it?
Thanks again.
Any idea's?
Thanks again.
