Woody, I see what you mean now, and now that you have put it like that it makes perfect sense.
I have never seen it done before, and I was curious as to WHY it is a bad idea other than "Its a bad idea" answers.
However, I'm still wondering if this really is such a large issue since its a relatively large mass with an evenly distributed static load on it.
If the ground had been disturbed underneath it or it was built half on bedrock and half on sand or something, I could understand it settling differently at each end, instigating tensile stresses.
However, on uniform load bearing ground, I very much doubt it will move to such a degree it will instigate large cracks, the whole mass would move as a whole instead.
If concrete can withstand these stresses alone, why wouldn't it be able to withstand it with the large joints to take up the stresses? It would be like an honeycomb structure.
Underlying point is, IF it moves significantly it is more likely to crack. But will it move to such an extent?
