I am going to replace my standard DHW cylinder with a DPS GXV mainly as a buffer tank for the central heating as I have a non-modulating boiler with Honeywell CM-Zone gear on all radiators (with automatic bypass to keep boiler flow going) and it's just not working well at the moment.
I was thinking of doing this myself, I've done other CH and mains and DHW stuff before and putting the heat bank in doesn't concern me greatly. They are not the most complex of things to work with.
However I am confused as to what I need to do with regards the building regulations. Do I need to inform Building Control that I'm doing this? If I get someone in to do it can they sign it off instead of Building Control? Any approved person type registrations I should be looking for?
My local Building Control department told me on the phone I don't need to inform them, but I'm not sure the receptionist knew what I was talking about. Could just run with that, but I doubt if that will help much if I should have got approval for it.
Thanks.
Thanks.
