I let a flat and have been advised by my Agent that I need an annual Service carried out Under Building Regulations for the electric unvented hot water system. Is this correct?
Good agent there. Its not always realised that all unvented cylinders need an annual service by someone holding the appropriate qualification.
As far as I am aware there is no particular certificate to be used so an invoice detailing the service will probably suffice. Some had a blue Benchmark Certificate with service record spaces.
