croydoncorgi said:AFAIK, its only Heatrae Sadia (genuine) Megaflos that use the airbubble system. But good point!
no its not !
oso hotwater cylinders also use this system and both require a full drain off every year to regenerate the air gap
The only other thought i have on the subject of putting unvented in the cellar is to put in a sump with a automatic pump to get rid of water same idea as a condense or saniflo pump arrangement but it would need to be able to withstand up to 95 degrees as some systems get this hot (Solar)
no its not !
Could you advise which sort of pump you would use for this? My plumber has installed the discharge outlet going in to a Sanivite (which is the higher volume version of the Saniflo designed for things like washing machines).
