Built using too much plasticiser
I don't actually know what that means,I thought someone might know-how much to put in with say 4 shovels of sand to one of cement! I don't know what a glug is either!
If youve got the ratio to water you premix in a drum or bucket and add it to your mix till its the right consistency,
doesnt mater if you use 4 or 8 shovels the mix is consistant
Actually it says 85Ml to 25KG cement!
Are you discussing using plasticiser, or a covid vaccine formula ? just put a small dollop in each mix and don't worry about it.
