builtunder double oven and separate hob
6 Mar 2010
Oxford
i have got to replace my built under double oven and hob. its wired in 6mm twin and earth cable from a cu b32 fuse to a 45amp ccu[13amp socket has well] then down to a box behind the oven then separate 6mm cable to oven and hob. my new double oven and separate hob have a connected total load of 11500w will my wiring be ok.
ps cable length is 10 meters
Yeah it'll be reet, because you wont ever actually pull 11500w (unless you turn everything on from cold at once, which probably will never happen).
This will make the job a little easier. ;)
if it helps see - hard wiring - oven / induction hob-what load can it handle? on next page 3/4 of the way down. i had help answering that one.
What do the manufacturers instructions say about the fusing required for the oven circuit? Or about the maximum size of conductors you can get into the terminals?
he says it wants to seprate circuits for the oven and hob he is coming round to do a install. :D thanks for replys
Open your window and ask him! :LOL:
<reference to the advert for a bank or something where the bloke asks "they" who are outside his window>
