Hello,
I'm very new and inexperienced to this game but could anyine please help with advice.
I have a large space and would like to dig a hole, approx 14ft x 10ft x 7ft deep. What would be ideal for foundations, walls, damp proofing etc? I plan to cover the roof in earth with a small doored access hatch of about 2 1/2 ft x 2ft 1/2 ft.
I was planning on using concrete for the floors and walls and ply with timber supports for the ceiling. How can I concrete vertically (for the walls????
Any advice would be HUGELY appreciated!
Thanks!
Jim
You need to shutter this with formwork . Like this......
PERI (German) is a good system and available for hire. It won't need a lot of steel reinforcing as the dimensions are small.
You say 7 foot deep. This is not that deep for an excavation but you need experience to evaluate the soil conditions and how it will stand up to becoming water logged after the excavation has taken place.
In summertime in the hot weather an excavation bank may produce a small crack, possibly not even visible to the eye and may be totally safe.
However in wet conditions everything changes.
The crack only needs water to seep in ,perhaps overnight.
If your lucky the bank will collapse during the night. If not then you may be in the hole when it does.
Its dangerous work and something best left to people with experience.
Having said all that because your dimensions are small the dig should be relatively safe as the corners are self supporting.
These are the safe points in a square dug hole and incapable of collapsing providing the ground is reasonably stable. An experienced excavator driver will know what you are dealing with the moment he drops the bucket into the ground. So listen to him.
I do this for a living incidentally. Ho hum.
We could complete something like this in 2 days from excavation on a green field to walls completed and fully decked out.
