Thanks , to test for bonded earth and neutral do I do a resistance check on the earth and neutral output pins , will this confirm ?I expected the generator would work but working and working safely are not the same. Some fridges and freezers do not like the earth and neutral not being nearly the same and I have had Honda generators in the past where the earth and neutral were not bonded but instead earth was connected to a tapping often around 55 volts away from neutral voltage.
I expect you will want to run fridge or freezer and rather than find out the problem after doing a load of work it is so easy to test with a meter that wants doing first.
I have also seen it where 110 volts where taken from one split phase with two 16A from another phase and a 32A from the third this would mean to use it would need two or three consumer units instead of one and you need to know about this before you start doing any work.
I hope the generator is straight 230 volt supply and all what I have said proves not to be a problem but better to test before you start on other work.
