I have recently had a couple of power cuts and when this happens my burglar alarm goes off and i cant seem to stop it , it does die after a while but in the meantime the nieghbours get jarred off , just wondered what the reason for this is .. Cheers mark
When you remove the panel cover the alarm will go into tamper (unless you have the engineers code). When the alarm goes off, typing your user code in will silence the alarm, but the system will show tamper until you replace the cover and reset the system.
SLA batteries are available from all electrical wholesalers, and maplin etc, or online here:
