And as for you pointing out that 6mm can be used to supply more power if it is ventilated is about as much use as farting in a lift. Have you EVER seen perforated tray in a well ventilated area in a DOMESTIC premises..Nope, thought not, so there is no point mentioning it.
See reference method 1 clipped direct 6.0mm=47amps.
OBTW..6mm T&E does not have a 2.5mm Earth core, it is and always as been 4.0mm. The designation on the cable mentions above is 6 stranded 2.5mm, which is OLD 2.5mm at that as all 2.5 mm is solid cored these days, and has been for over a decade.
Old (2.5mm) is 7strands referred to as 7029.
6.0mm has 2.5mm earth core
Dam, we have already establish that the cable is 2.5mm NOT 6mm. [/quote]
No you assumed.
He has already stated that he used cooker sized cable in his replacement.
This i would have advised uprating to 10.mm incase he upgrades the shower as has already been suggested.
As mentioned earlier the problem is most likely due to loose connections in the switch more than the cable .
