I'm just curious. Whilst strolling through B&Q, as one does, I noticed that the instructions on plastic cold water feed tanks said Do not use a hot tube to cut a hole in the tank. When I fitted these things, many years ago, I used a heated copper offcut to 'cut' the holes, and a wonderful, circular, stress-free job it did as well. You had to peel off the melt around the rim of the hole, but I doubt whether I could ever get such a neat job from any mechanical means.
So why is it verboten? Fumes, or some other reason?
