to burn a hole. it weakens the integrity of the plastic in the area where you have heated it up, which is also where its strained. certain plastics can only be heated up at moulding time....not repeatedly.
You're guessing, aren't you!
How does it "weaken the integrity"?? How do you know? Sounds like Bull!
The "certain plastics" you refer to are "thermosets", but tanks are all made of "thermoplastics", which means that if you heat them up, they melt.
The plastics are such poor conductors that only the part right next to your hole would get above normal working temperatures of the tank (they stand boiling water without doing more than going soft..) All the fittings have quite wide flanges so I really don't see any effect at the very edge mattering . The melted swarf which comes from the hole isn't brittle once it has solidified anyway, it's just like the rest of the tank material.
There is a mechanism by which some poor thermoplastics can become brittle if exposed to UV or held at very high temperatures for extended periods, but if wouldn't apply here. (Washing-up bowls left outside, exhibit it.)
There could be a FIRE risk in using a glowing red pipe, perhaps. Maybe that's why they say what they do.
I'm never keen to use a blowlamp in a loft at all.
I agree that it's a pain, but if I drain a cistern, for whatever reason, I vaccuum it out
If I'm just adding an outlet for a shower, I wouldn't fully drain the cistern
