arbitrarily increased by 7.64% from 92.9 to 100m² (solely because of bureaucracy) with no regard for the consequences.
What consequences?
Don't think it was - the relevant text in the 16th OSG refers to a regulation which does not specify a limit.It was a Regulation in the 16th Edition too.
I'm not sure which way you are arguing.Because it's only a guideline, and 1076.39ft² makes as much sense as having jars of jam weighing 454g.
I wouldn't actually say "meaningless" but, rather, an almost arbitrary (hence necessarily 'approximate') round number.Agreed, but doesn't that show that the 1000 sq.ft. was meaningless?
Yes, as I implied, probably - but would you say that meant that the previous 30 mph had been 'meaningless'?I think it would be 50kph - as in Europe.
Yes, but it's not black and white - it's not exactly 'arbitrary' - but it is dependent on one's view as to what is the acceptable level of risk/injury ....Anyway, the 30mph and 50kph were, presumable set as duly considered relatively safe in the event of an accident.
The floor area figures and speed limits were both introduced because someone considered those to be reasonable ('approximate', hence round figures) places to draw the line - in terms of their judgements about what it was likely to mean in terms of electrical loads, and what it was likely to mean in terms of a vehicle impacting a person, respectively. However, as I said, that 'where to join the line' is a judgement, based on all sorts of things, not something that is 'right' or 'wrong'The 1000 sq.ft. and 100 sq.m. are totally irrelevant to a ring circuit unless you think the speed limit was introduced because your car covers an area of 90 sq.ft.
I don't think the vocabulary makes any difference. I would probably say something like 'imprecise to the extent of being of little value as a generalisation'. There obviously is an underlying 'electrical consideration' (an estimate of the electric load likely to be applied to the circuit) - but the problem is that floor area is, as a generalisation, a very imprecise measure/estimator/predictor of that.Perhaps I should have used the word pointless instead of meaningless - although the area limit does mean nothing in electrical considerations.
FHS, EFLI, it was a guideline - why are you so hung up on how much meaning there is in the difference between 90m² and 100m², or 1000ft² and 1076.39ft², (or either of those and 100yd², which could have just as well been the old imperial guidance)?Agreed, but doesn't that show that the 1000 sq.ft. was meaningless?
If important, and relevant to anything, it would surely have been changed to 90 sq.m.
No - he is trying to show you other examples where a value is chosen because people, rightly, want limits that are nice, round, easy to remember numbers, and the same applies to guidelines.That may be so, but you're doing what you frequently do - introducing an apparent (in my view invalid) comparison and then discussing (arguing about) that.
And sorry, old chum, but I simply do not accept that you genuinely found his analogy so abstruse that you think there has to be a connection between speed limits and car sizes.The 1000 sq.ft. and 100 sq.m. are totally irrelevant to a ring circuit unless you think the speed limit was introduced because your car covers an area of 90 sq.ft.
