is there such a thing as a steel plate to fix to a joist when this sort of thing is needed?
Just a flat plate with maybe a chunk missing around the centre and predrilled holes?
Maybe on on each side
It would need to be two specially made steel plates and bolted through the timber. Might a possible solution be running two or three 15mm pipes in parallel, side by side, rather one large pipe?
