Regulation 522-06-03 just talks about cables, ducts or conduits being a sufficient depth to avoid being damaged by any reasonably foreseeable disturbance in the ground
As a general rule I have always done the following:
Lay it in a trench at least 450mm deep under a path or driveway, or 750mm deep below unpaved areas that may be dug up at some point. Run electrical route marker tape above the cable at a depth of about 150mm as an extra precaution.
Is there a regulation with these depths mentioned?
