dear all, had a very unusual dilemma today while fitting my kitchen fan before carpets go down tomorrow.
Pulled cable through ceiling void and Linked brown to permanent live, grey to neutral, black to switched live, and earth to earth, in a junction box specifically installed for this purpose.
Went to test without switch and fan connected, and brown live at fan but switched live is also live. Bearing in mind the power doesn't get to the switch yet and the only wire that should be live is the permanent live.
I checked connections, triple checked the cables were correct, and stripped back the cables to see if they had connected ! Nothing!
So I pulled another length of 3 core and earth through and this time just connected the brown and nothing else. This time all three other cables were live. I cursed the cable manufacturers and pulled through a length of two core and earth, slightly bigger at 1.5mm and pulled a separate brown cable through with it.
I wired it all up feeling confident and wallah it's all ok!
My questions are , has anyone else had this happen? Is it the cable? Am I missing something?
I've tried a continuity test on the pieces of cable I used but it seems fine!
