- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
With 50Hz cable lengths and use of coiled coil bulbs is unlikely to cause a problem the resonant length would be huge.
However with lighting inverters the frequency can be quite high and I wonder about cable lengths? With the old tordinal transformer I would use 4mm twin core to power 4 lamps around the room from one central unit my only worry was volt drop.
However I have not seen any information about cable lengths with inverters and at such high frequency one would expect just like a CB radio the voltage standing wave ratio would be critical and if wrong would cause over heating and premature failure. Also of course if the cable is not matched it could transmit and cause EMC problems.
Does that mean with inverters when powering 4 lamps there is a maximum cable length irrespective of volt drop?
Is this the reason we hear so many complaints about lighting inverters having a short life when compared with a tordinal transformer?
