Cable size help
23 Jun 2009
Blackpool
Evening, i am installing 3 x 2100w hand dryers on one circuit. Each dryer will be fused with a 13a FCU.
As each unit is individually fused can i use 2.5mm on a 16a breaker. Or do i need to run the whole circuit in 4mm?
9 amps each, and 3 of them on a 16A breaker?
Presumably they could all be used at the same time.
Clearly not going to work.
I wonder how much longer you'll be able to get away with working as an electrician, posting questions on a DIY site to try and cover up your desperate lack of competence?
